She was smokin' when I stopped.
Jim Handke
11-20-2003 18:53:12
I did it now boys! Tore thr rear end outta a 2470. Didn't think it could be done. Heard a growl when I was pulling the chisel, was afraid it was a bearing going out in the manual transmission. After I stopped in ther yard, and the dust cleared, I could see smoke wisping up. Can't see that in the field, because of all the dust in the lights. Looks like I'll put the other one on and keep plugging away. Anybody who wants to help work on this later on, let me know and I'll send you a map:).
John Saeli
11-21-2003 04:30:34
 Re: She was smokin' when I stopped. in reply to Jim Handke, 11-20-2003 18:53:12
Hey Jim; Sorry to hear that. Sounds like a bearing got hot somewhere. Plowing this fall with the 4690, I blew another manifold gasket. About every 2 or 3 years.
Jim Handke
11-22-2003 17:28:13
 Re: Re: She was smokin' when I stopped. in reply to John Saeli, 11-21-2003 04:30:34
Got a good look in the daylight. The pinion shaft was sticking 2 or 3 inches out the front. Bearing carrier looks good. Maybe two bearings and a seal will fix her up.
Les...Hey John
11-21-2003 09:38:25
Speaking of manifold gaskets, you don't happen to have on for my SC do you?
G. L. Perry
11-22-2003 14:19:31
 Re: Re: Re: She was smokin' when I stopped. in reply to Les...Hey John, 11-21-2003 09:38:25
Yes, case still has, I just got some. Priced Individually at about $8 each believe it or not. Since when can you replace just one? Expensive,but what you gonna do? They are metal two sides and large "sqish" area in middle.
John Saeli
11-21-2003 19:55:04
Hey Les; Last I knew they were still available from CASE. I don't have any in stock.
