why not an 1175
kevin jones
11-20-2003 15:57:20
I'm just curious about the 1175 for a puller.
Why not put a 504 motor on that tractor and run it about 3500rpm's and put light weight wheels on it.
I like it because there is no power shift to go out,it shouln't be that heavy either with 18-38's on the rear.
What about getting air to it,is that much of a problem.
Should be able to get plenty of fuel with that in-line pump.
Just curious.
Kevin.
Dale
11-23-2003 22:34:58
 Re: why not an 1175 in reply to kevin jones, 11-20-2003 15:57:20
there is one that turns 5000 rpm's here near here. he had to go with a dubble disk clutch ,he did him self to hold the power.
Lamont
11-20-2003 19:25:36
I don't know how light of a puller you can make out of an 1175 since they have the big planetary setup. They're pretty heavy. I do know you can put a 504 on them. With a little money for different parts you can crank 600 plus HP out of a 504. You'll need 2870 heads so you can use the intercooler. 2870 injectors. Take the shims out of the front of the fuel pump. Give it a real healthy dose of fuel. Run it 3250 rpms. You're setting right at 600 HP with basically a stock 504. Put the 1175 in 7th gear and tell everyone to get out of your way. The only trouble my friend's 1370 had was occasionally twisting a turbo shaft in two. It never did hurt the engine. All the parts fell right into the intercooler. You'd probably be better off finding a turbo a little heavier than the Airesearch factory turbo. They just weren't made for those rpms and pressure. Give Steve Merritt a call at 501-268-4244. They don't pull anymore, but he can tell you more details. I don't know what size classes they pulled in, but I do know that in the heaviest class they had 99 weights hanging on it.
hoop
11-23-2003 17:12:09
 Re: Re: why not an 1175 in reply to Lamont, 11-20-2003 19:25:36
be careful, when you start turning the higher rpms that's when stock flywheels come apart, it happened in kentucky this last summer with an a/c and killed a spectator, try to find you a steel flywheel, then let-r-rip
