Is .008 too much?
Glenn Fitz Ge
11-20-2003 10:29:19
The fellow at the machine shop assures me .008 wear on 4" DC sleeves is no problem. This is the worst of the four. What do you think? Bearings=very good. New cast iron rings. Occasional heavy pulling. Will it use oil?
DKase
11-20-2003 13:12:32
 Re: Is .008 too much? in reply to Glenn Fitz Gerald, 11-20-2003 10:29:19
I have a reversed DC with a loader in it. Bought it cheap because it had a knock that sounded like a rod. When the rods checked out good I went searching for the problem. I can fit a .050 feeler gauge in beside the piston from the bottom. The knock actually stops when it warms up. I have the parts, but not the time to fix it. It has run that way for chores every day for 3 years! It doesn't even use oil. Those old slow engines will take a lot if you keep the RPM's down.
CASEPOWER
11-20-2003 10:37:43
It's a lot. I would put a new ring in and check the end gap before I went to far.
