How much cylinder wear can I get by with?
Glenn Fitz Ger
11-20-2003 09:54:38
I have a DC engine with 4" sleeves. The worst one is .008" worn. If I use cast iron rings can I get by with it? Is it going to use oil? I won't be pulling it hard too often. Bearings and crankshaft are excellent. Machine shop assures me the cylinder wear will be no problem.
todd hamilton
11-20-2003 18:25:13
 Re: How much cylinder wear can I get by with? in reply to Glenn Fitz Gerald, 11-20-2003 09:54:38
I don't know about a DC but an SC will run pretty well without all of it's rings. When I cleaned the bottom of my oil pan the first time I found a piece of ring. Engine doesn't knock or foul the plugs. It does use "a little" oil. We call her "Old Smokin' Bushpuller." I will get the engine rebuilt someday. Meanwhile, I keep extra oil on hand at all times!
kjm
11-20-2003 18:09:53
Glen, Use what you want, but iron rings are hard to seat and easy to break. kjm
dctom
11-20-2003 10:30:45
I woulddnt think that would hurt, chrome rings are your best bet i beleive tom
Glenn FitzGerald
11-20-2003 13:32:57
 Re: Re: How much cylinder wear can I get by with? in reply to dctom, 11-20-2003 10:30:45
DC Tom , or anyone...I forgot to ask this on my last response to Tom, How much cylinder clearence were DC's set up with from the factory? This engine I'm talking about, I don't have it all together yet, but one of the pistons was worn so I replaced it with a good used one. There aren't too many elementary school teachers that have an old 4" Case piston for a pencil cup. You can't buy them at the local office supply store! I get some interesting comments.
Glenn Fitz Gerald
11-20-2003 13:20:28
Tom, I'm sure you know more about it than me, but the logic behind the cast iron rings is they supposedly seat up better and stay seated better. However, they don't last as long. I sure appreciate your information.
