case 732??
Tooly
11-20-2003 09:43:48
A friend of mine has a Case tractor , which he says is a model 732. I am not familier with this model, and haven't actually seen the tractor.
My question is regarding the brake system used on these tractors. Brakes are almost non existant,and I would like any information on what it would usually take to fix them. Thanks
KIRK-TX
11-20-2003 16:21:52
 Re: case 732?? in reply to Tooly, 11-20-2003 09:43:48
I have a 830 CASE and just fixed the brakes. One side was fairly easy. It has 2 disks that will need to be replaced. You may have to resurface the "rotor". Inspect the balls and seats for smooth surfaces and springs for tension. One side on my tractor was full of dirt and all parts were rusted together. The disks had worn the shaft because they were locked up. After lots of work, I got them cleaned up & fixed. I don't remember the cost off hand. By the way, the brakes are under the platform in front of rear axle.
John Saeli
11-20-2003 15:19:33
Hey Tooly; The brakes on that 730 are double disc with a mechanical actuator in between. They are easily dissassembled. Take the covers off, dissmantle the actuators, clean them up, get the rust off the braking surfaces, install new discs if needed & reassemble and adjust..
tooly
11-20-2003 20:34:25
 Re: Re: case 732?? in reply to John Saeli, 11-20-2003 15:19:33
Thanks guys , thats the answer I was hoping for, my friend will be happy to hear this repair should be fairly reasonable cost
