DC Case serial number......year?
Glenn Fitz Ger
11-19-2003 19:57:22
I checked my DC serial number. It is 6022592DC. The only other possibility is that the first digit is an 8, but it sure doesn't look like it. What year is this DC and where was it made?
dctom
11-20-2003 06:29:21
 Re: DC Case serial number......year? in reply to Glenn Fitz Gerald, 11-19-2003 19:57:22
Glenn: dose the block number and the tag number the same? block number should be stamped on engine flange right behind the air cleaner tom
Glenn Fitz Gerald
11-20-2003 09:39:16
 Re: Re: DC Case serial number......year? in reply to dctom, 11-20-2003 06:29:21
Tom, it will be a while before I can check that out. The original block (what's left of it) is 130 miles from here. Thanks
Brian in Ohio
11-20-2003 05:15:08
O'm sure DC Tom will correct me if I'm wrong, but your DC is a 1956.
dctom
11-20-2003 06:26:30
 Re: Re: DC Case serial number......year? in reply to Brian in Ohio, 11-20-2003 05:15:08
Glenn/ Brian glenn are you sure of that number there is no 8022592, first 80 number is 8022746 and i see no 6022### numbers at all
brian, it cant be a 1956 as there were no DC's built after 1954, I will do more checking and see just what is going on unless the number is wrong From what i see here is it is a 1953 tom
jal-SD
11-20-2003 06:22:02
The first # is probably an "8". Generally, you have to subtract 4 from the first two #'s, but Case changed the numbering system in 1953 & started its serial #'s with 80, at least for the S & D series, don't know about the LA & VA series for sure, but think these were changed too. I've seen the break where they went from '53 to '54 models, but don't remember where I saw it. Your DC is probably either a '53 or '54. 1954 was the last year of production for the VA, S & D model series. Does it have a foot clutch & both brakes on the right?
I think dctom might be able to tell you when it was built & shipped from the build cards he has. (My $0.02 worth. jal-SD)
