Case L governor parts
Brian in Ohio
11-19-2003 08:57:36
It seems I'm going to need to rebuild the governor on my 1934 "L", and was wondering if there were any other tractors, other than say the "LA", that used the same governor in which parts may be a little easier to obtain? My father thought that a 400 used the same governor. Is this true?
Glen in TX
11-20-2003 14:53:23
 Re: Case L governor parts in reply to Brian in Ohio, 11-19-2003 08:57:36
There were 2 different governors used on the LA but not sure if they will work on the L. Cleaning out bins this week I found a bare governor outside case that could fit the L. It has casting no. 4461A on the inside and had some blue/gray paint on it. Used but the bushings and hole for shaft show no wear. Not sure about other governors to fit it.
Brian in Ohio
11-20-2003 18:02:38
 Re: Re: Case L governor parts in reply to Glen in TX, 11-20-2003 14:53:23
I'm going to check my parts book to see if that number is for my L. The Ls had two different ones depending on when they were built. What would you have to have for yours, if I can't locate replacement parts for mine? Email me and let me know...
