Case 530 Diesel - generator to Alternator Conversi
dennis
11-18-2003 19:53:29
I have a 1968 Case 530 Diesel Backhoe - Tractor - It has a Generator and a Positive Ground Electrical system. The generator does not work.
Is it better to just replace the generator with a rebuilt one OR convert the electrical system to an Alternator?
If I convert it to an Alternator HOW DO I DO IT.
How do I convert from a POSTIVE ground to a NEGATIVE ground , Will the starter and other electrical parts work correctly.
WHAT DO I HAVE TO DO, STEP BY STEP in Converting to an ALTERNATOR Electrical system.
Thanks
Dennis
Doug in OR
11-23-2003 11:22:17
 Re: Case 530 Diesel - generator to Alternator Conv in reply to dennis, 11-18-2003 19:53:29
The starter will work fine. If you have an ammeter, it will read backwards. You can remedy this by reversing the leads (all of them) on the back of the meter. As long as you have no other "electronic" guages, everything else should be fine. You will need to run a wire from your master swirch to the "exciter" terminal on the alternator. Since this is a diesel, no diodes or lamps should be necessary. There are more detailed instructions in the "articles" sections to the left of this page, I believe. Look the conversion info articles over and leave me a note if you have any questions. I believe much of the info is about converting from 6 to 12 volts. Ignore the part about changing the voltage. You need to only note how to install the alternator.
Dennis/Ohio
11-22-2003 16:27:17
Hi Dennis,
I can answer part of your question. The starter will work either way.
Isn't your tach drive on the back of the generator? If so, I think I'd have the generator rebuilt.
Best wishes, Dennis.....
