D SERIES SLEEVES
bill
11-18-2003 17:41:32
I need TWO 4inch sleeves for my D-C I could have some 3 and 7/8 bored i guess Is there any one who knows EXACTLY what they should be bored to????? ?? Come on DC TOM let me know
caseman-d
11-19-2003 11:56:06
 Re: D SERIES SLEEVES in reply to bill, 11-18-2003 17:41:32
A26324 is a good number, they list for 66.66 ea.
caseman-d
ps They do not include the orings
bill
11-19-2003 17:20:53
 Re: Re: D SERIES SLEEVES in reply to caseman-d, 11-19-2003 11:56:06
Dont any of you guys have a couple of decent used 4 inch sleever you wold sell??
dctom
11-18-2003 18:52:31
i have done that many times bored 3 7/8 to 4 inch than honed them to get a good fit no problem tom
C. Amick
11-19-2003 09:57:31
 Re: Re: D SERIES SLEEVES in reply to dctom, 11-18-2003 18:52:31
How do you hold the sleeves to bore them? Don't they want to spin in the block?
John Saeli
11-19-2003 05:24:00
Hey dctom; I just curious; Why would you bore an old sleeve that undoubtly has cavitation started when new ones are readily available? I'm considering machining costs and clean-up: all those metal chips dropping down in.
C. Amick
11-19-2003 09:59:58
 Re: Re: Re: D SERIES SLEEVES in reply to John Saeli, 11-19-2003 05:24:00
You can't still get SC sleeves from Case can you? I'm still looking for some 3-11/16" ones.
John Saeli
11-19-2003 15:43:18
 Re: Re: Re: Re: D SERIES SLEEVES in reply to C. Amick, 11-19-2003 09:59:58
Hey C. Amick; You mean 3 5/8 sleeves, right?? Those sleeves are still available for the 5600A block. I checked today.
C. Amick
11-20-2003 05:47:32
 Re: Re: Re: Re: Re: D SERIES SLEEVES in reply to John Saeli, 11-19-2003 15:43:18
No, Don L. says that the pistons I have are 3-11/16" based on the number stamped on them. They are the aluminum button topped pistons. Do you know if the sleeves for the 5600A block have a single "O" ring seal of a double one?
dctom
11-19-2003 06:23:21
did you ever price a new sleeve from case ???
bill
11-18-2003 18:57:58
Tom did youi bore to exactly 4 inches then hone? I have a neighbor with a lathe so boring should be no problem I seem to recall that chuck should not be so tight as to distort sleeve Any tips on how to turn the sleeve out???
george md
11-18-2003 21:22:57
 Re: Re: Re: D SERIES SLEEVES in reply to bill, 11-18-2003 18:57:58
Guys , bore them in the block with cylinder bar, put one in at a time , set bar on block where there are no sleeves. Boring in the block is better than boring in the lathe , doesn't distort the bore from holding in chuck. I bore and sleeve cont'l and waukesha liners quite often.
george
dctom
11-18-2003 19:05:21
yes bore to 4 " he will need a good support under the sleeve and a strong boreing bar clamp it from the top where it wont distort take lite cuts so you dont have to clam[p so tight tom
John Saeli
11-18-2003 17:56:59
Hey Bill; I don't have the part # here at the house, but those sleeves are readily available from CASE. I'm thinking about machining cost and the pitting in the old sleeves.
Tom Railsback
11-18-2003 18:10:11
 Re: Re: D SERIES SLEEVES in reply to John Saeli, 11-18-2003 17:56:59
The last part numer I have (sub book) is A26324
My sub book is about 14 years old, but I am willing to check part numbers for C, D, L, LA, & S series. I have all of those parts books too.
Tom Railsback
11-18-2003 18:14:35
 Re: Re: Re: D SERIES SLEEVES in reply to Tom Railsback, 11-18-2003 18:10:11
JUst noticed, I used the wrong E-mail address on
the previous post.
I think Case's computer system can convert original part numers to the latest substitution numbers. John, you can correct me if I'm wrong on this.
John Saeli
11-19-2003 05:19:46
 Re: Re: Re: Re: D SERIES SLEEVES in reply to Tom Railsback, 11-18-2003 18:14:35
Hey Tom; I'm not sure, cause sometimes the parts counter will tell me I have an invalid number, but then they look somewhere & then they tell me it's a changed number and we go from there. I think too many parts men give up when they see invalid # and don't check further.
Tom Railsback
11-19-2003 18:19:28
 Re: Re: Re: Re: Re: D SERIES SLEEVES in reply to John Saeli, 11-19-2003 05:19:46
John:
I guess I'm lucky because I have a parts man I've trained myself over the last 15 years. He has
been with four different dealers in that time and
he's fairly sharp. But, like I said, I guess I'm lucky. I had good training back in the 60's just
accompanying my dad when he went for parts. I
learned to read the books and then in 1973 a
dealer gave me a new LA parts book he had lying around; the rest is history.
