Case 430 loader problem
Dennie
11-18-2003 12:21:07
Friend has Case 430 (1966) with apparently Case loader which, when lowering, Chatters badly. When attempting to raise the bucket, it is very low on power. Roll of bucket works fine. Is there a floating valve in boom line(s) which could be clogged/damaged or is problem in control valves under seat, etc.? At one point this summer it worked for a while but would not stay up when raised. If control valve problem, please give range of difficulty 1-simple , 10-very difficult. thanks for any help that you can give.
dbock
11-18-2003 18:55:58
 Re: Case 430 loader problem in reply to Dennie , 11-18-2003 12:21:07
I had a 530 that had similar problems. It turned out the problem was the screen on the bottom of the intake tube to the hydralic pump was clogged. I cleaned it and it works fine now.
