Seized up L
Tom Railsback
11-17-2003 18:58:58
I bought a 29 L on auction 7 years ago; it was free, but I figured it needed a valve job so I pulled the head and put on one that had been redone. I had it running and shut it down and let it set for a couple of weeks. One Saturday I went to start it and it had seized up. I pushed it into the garage, put a 36 inch pipe wrench on the crank pulley and it came free. I had the original head redone, put it on, belted up to my C, spun it awhile, got it running and shut down for last winter. A week before our St. Patrick's Day parade, my IHC friend and I pulled it, it almost started, but ran out of gas. We went and got 5 gallons, put it in the tank and started up the street again and it seized up again. This
tractor has the early style push rods with sockets on both ends and 1/2" balls that sit to top of the lifters; the lower end socket fits over these balls. Could I have gotten one of them out of place and caused it to lock up?
By the way, 2004 is the 75 anniversary of the introduction of the L and C series tractors, so I want to have this one running. Any suggestions?
CASEPOWER
11-17-2003 21:20:33
 Re: Seized up L in reply to Tom Railsback, 11-17-2003 18:58:58
It sounds like a piston gaulded and it causeing it to lock up. Is it tight when it does turn?? Did you inspect the cyl. walls good when you had the head off?? I had one that would lock after it got hot. I took #4 piston out and filed it smooth were it messed it up then honed for a long time to get the cylinder clearance I needed.
