Case 660 combine motor swap????
Doug Franks
11-17-2003 17:41:08
I have a 660 combine with a good motor. What tractors will this bolt up too?? Ive heard they will work in a VAC . Is this right??? Thanks ! Doug
Fred Mauro
10-31-2005 15:20:56
 Re: Case 660 combine motor swap???? in reply to Doug Franks, 11-17-2003 17:41:08
I have a case 310 dozer that needs a motor a friend of mine has a case 660 combine with a 201 gas. Will the moto fit my bell housing
philcase55inWPa
11-21-2003 08:47:54
I have a case 630 tractor with a gas 188 engine that threw a rod this summer. I have read on the discussion boards that the 600 and 660 combines' engines will fit a 630. Are you interested in selling the engine? If so how much etc. I am in W PA and used to drive to Indiana a lot taking my daughtet to college.
J Kelnhofer
11-18-2003 06:30:13
A motor from a 630 will fit. 188 ci gas.
INCase
11-18-2003 04:58:44
where are you located?
Doug Franks
11-18-2003 14:42:00
 Re: Re: Case 660 combine motor swap???? in reply to INCase, 11-18-2003 04:58:44
Thanks for the info! I'm in NE Idiana, just west of FT Wayne
David
11-19-2003 17:53:42
 Re: Re: Re: Case 660 combine motor swap???? in reply to Doug Franks, 11-18-2003 14:42:00
hey did you know a diesel and gas have the same crank you just need to have the other two throws finished at a machine shop for a 188.been there done that.
