case 444 hydraulic problem
Steve Weaver
11-17-2003 15:50:13
I have a 444 i think it is around a 74. when i rev it up it is like the engine is fighting hydraulic pressure to the point that it pulls the engine down. when i idle it down it runs fine. I did replace the spool valve with a used one i bought off of ebay. same problem! maybe i bought a bad valve could someone please help. THANKS
Klyde
11-17-2003 16:22:18
 Re: case 444 hydraulic problem in reply to Steve Weaver, 11-17-2003 15:50:13
74 has the oil tank up in front, over the cooler, right? If so, there is a screen in that tank that has probably broken loose and is laying over the outlet, and that really loads the engine down, as well as making the pump cavitate .... just a thought.
Steve
11-23-2003 08:57:32
 Re: Re: case 444 hydraulic problem in reply to Klyde, 11-17-2003 16:22:18
took the hydro tank off everything is clear tractor still doing the same thing only new thing i know is when it is fighting itself i am losing pressure on the return i did take the spool vale apart to see if there was any blockage and there wasnt. running out of things to check. HELP
