Endfloat settings and backlash data for a Case SC
Dave
11-17-2003 15:05:22
Hey guys,
I know get a service manual and find it there. Well I'll ask the collective brains of the forum.
I have to do the bearing on the output to the break disk on the left side. First is there room to do it without going in. If not can anyone help with the float or preload settings for the int shafts. While I am in there I am going to replace all bearings and seals, no use having to go in again at a later date.
Thanks to all Dave/1948 Case SC
Bruce Nelson
11-17-2003 17:24:11
 Re: Endfloat settings and backlash data for a Case in reply to Dave, 11-17-2003 15:05:22
Dave, you can replace the bearings and seals from outside the tractor. The adjustment for the shaft is not end play (end float) but a slight preload. Bruce
Dave
11-18-2003 07:49:58
 Re: Re: Endfloat settings and backlash data for a in reply to Bruce Nelson, 11-17-2003 17:24:11
Bruce,
Thanks I will try going in on the side of the tractor.
Dave
