david brown 880 3pt
Robert
11-16-2003 20:14:27
Does anyone have an idea what might be wrong with my 880 selectamatic the 3pt lifts slow ony at full throtle and will not stay when idled down it will only lift about 50lbs. it just quite one day afther working for a few hours mowing
Elmer
11-17-2003 04:00:55
 Re: david brown 880 3pt in reply to Robert, 11-16-2003 20:14:27
Sounds like you might have a blown Oring behind the pump. There could also be a piston seal gone on the lift cylinder. A cracked pressure line could be a problem too. I can supply a manual if you need one.
Robert
11-17-2003 12:13:25
 Re: Re: david brown 880 3pt in reply to Elmer, 11-17-2003 04:00:55
I have a manual i will let you know which kind it is a sone as i locate it agian
Robert
11-17-2003 17:22:50
 Re: Re: Re: david brown 880 3pt in reply to Robert, 11-17-2003 12:13:25
Yes the manual I have is a I&T shop service manual if the is the one you have what paragraphs I should look in.
Elmer
11-17-2003 18:11:08
 Re: Re: Re: Re: david brown 880 3pt in reply to Robert, 11-17-2003 17:22:50
I have the original David Brown publication. The I&T is enough to make you dangerous!!!!! I sell copies of these.
Robert
11-18-2003 20:15:47
 Re: Re: Re: Re: Re: david brown 880 3pt in reply to Elmer, 11-17-2003 18:11:08
How much does the manual cost.
Robert
11-18-2003 20:44:46
 Re: Re: Re: Re: Re: Re: david brown 880 3pt in reply to Robert, 11-18-2003 20:15:47
Also can you tell me if my david has a two stage clutch one for the pto because it dosn't act like it has one.and should I worry about using my manual on any other problems.
wayne
12-01-2003 07:03:24
 Re: Re: Re: Re: Re: Re: Re: david brown 880 3pt in reply to Robert, 11-18-2003 20:44:46
Robert
With DB hydrulics you have an internal leak this could be an o ring on your main lift cylinder
or an internal pipe has split you can test your lift cylinder by lifting it and then turning off im thinking you`ve got a red implimatic.
wayne
12-01-2003 07:09:22
 Re: Re: Re: Re: Re: Re: Re: Re: david brown 880 3p in reply to wayne, 12-01-2003 07:03:24
Robert
Sorry you`ve got a selectamatic you still should be able to lock of the piston.
Another thought it could be an o ring on the back of the hydrulic pump witch can blow as well
