Vac Eagle hitch? for Sam #3
Tom
11-16-2003 16:39:45
Clarification; yes I guess I mean the rockshaft. So what your saying is no oil should go down the rockshaft to the left unless the piston is leaking it down there? I assume that manual RIE61 is available at the CaseIH dealer? I am an IH collector so this is new territory for me. Also new to this website, but I am really surprised how helpful everyone has been. Thank you.
Joe (Wa)
11-16-2003 19:52:21
 Re: Vac Eagle hitch? for Sam #3 in reply to Tom, 11-16-2003 16:39:45
Tom, far as I know there are only two ways that oil can leak out the rock shaft ends:
1) the leak-off tubing for the housing under the piston is plugged.
2) the lift valve or release valve is leaking out through the valve stem.
Joe
Sam#3
11-16-2003 17:57:52
That's correct. The shaft is greased via the zirks and all the oil should be contained in the top of the cylinder. My VAC had sat for a long time and was completly dried. In addition to the piston the depth control and the pump seal were also leaking.
Yes, I obtained the RIE61 about two months ago.
