case 1030
Steve Marston
11-16-2003 12:17:16
Does anyone know if i could put case 1370 sleaves into a 1030 block, and if it is possibe would the original crank shaft work or would everything have to be different.
Steve Marston
11-20-2003 09:25:07
 Re: case 1030 in reply to Steve Marston, 11-16-2003 12:17:16
Thank you all for your time and information, I appreciate it.
Jens Andersen, Denmark
11-17-2003 11:52:19
Be carefull about the rearend. That tranmission is
from what I heard the same as in the 830 and 930.
Even with only the original 1030 engine it could
ruin the finaldrives or even break the rearaxle.
Best wishes, Jens Andersen Denmark
Jim Handke
11-16-2003 15:01:10
The block would have to be bored out. I don't know if the stock rods can work with the 1370 wrist pins, and if they don't, I don't know if the 1370 rods will match the stock crank. Tractor pullers, we need help with this.
John Saeli
11-16-2003 17:14:29
 Re: Re: case 1030 in reply to Jim Handke, 11-16-2003 15:01:10
Hey Men; One thing for sure, the 1030 cooling system will never keep a 504 cool.
Jim Handke
11-16-2003 18:50:26
 Re: Re: Re: case 1030 in reply to John Saeli, 11-16-2003 17:14:29
You're right as rain about that. Working wheat ground in August here pushed it to the limit and beyond.
nna
11-16-2003 23:32:45
 Re: Re: Re: Re: case 1030 in reply to Jim Handke, 11-16-2003 18:50:26
The 70 series engines run cooler than 30 series- the radiator will be fine. I beleave 1170 or 2090 rods will work, they will fit the 1030 crankshaft and the wristpin for the 4 5/8" piston. I can check the specs tomorrow to verify this.
