What Happened To My DC?
Wide Open
11-15-2003 13:59:10
OK. The story goes like this. About two weeks ago I used my 1944 DC to pull a 14' IH tandem disk so i could smooth out a rough spot in the field. It pulled it good in 2nd gear with no problems. When I was finished I cleaned the tractor off and put it away in the shed for the winter. Today I went to check anti-freeze in all of my tractors to make sure they are good for winter. When I came to the DC I took off the cap and THE RADIATOR WAS DRY! NO ANTIFREEZE. I then checked the oil and pure anti-freeze shot out. When I had used it two weeks before it was full and I never had a problem when using it on the disk, so .. something must have happened while disking. Could I have blown the head gasket? The head gasket always had leaked oil down the outside of the block, but never water into the oil. Could have even cracked the head or block? It never got hot or anything while disking, but it did pull somewhat hard at times. Would this blow head gasket? Another thing I thought about was seals on sleeves? Any help or thoughts would be appreciated. Thanks.
bill
11-16-2003 12:19:13
 Re: What Happened To My DC? in reply to Wide Open, 11-15-2003 13:59:10
I sell the O rings for bottomof sleever for $29.00 for set of 4 Includes postage 406 827 3006
Tom Railsback
11-17-2003 18:44:33
 Re: Re: What Happened To My DC? in reply to bill, 11-16-2003 12:19:13
Bill:
I think we need to have a Montana Case get together sometime, someplace. Great Falls is about the most centrally located large town.
No show, just lunch or dinner and bs. I could
probably get Dick Cassut, an old CASE dealer to
come and share some of his stories.
What do you think?
Tom Railsback (406) 454-8758
dctom
11-15-2003 14:07:41
take covers off hand holes and check each sleeve with flashlight, should be able to see if antifreze is leaking from one of them, heating up will make old hard one leak all at once tom
