Time to install new hydr pump
Eddie in KY
11-13-2003 16:40:36
Hey guys, I'm a fairly competent machanic. I just have never replaced a DB hydraulic pump. It's on an 885, and in a month or so it's gonna be replaced. How much time should I allow myself. I have the tools and books, but I just don't know how much time it should take. Any info will be appreciated. Hey Elmer, what would be the cost from you shipped to 40142 in Ky be.
Thanks all,
Eddie in Ky
Elmer
11-14-2003 09:26:46
 Re: Time to install new hydr pump in reply to Eddie in KY, 11-13-2003 16:40:36
Pump cost is $400.00 and $12.00 for postage. U.S. funds. The other post is right on in time. And yes make sure you remove the light swith manifold first under the pto housing.
turbo
11-13-2003 17:21:16
If this is one of the models with that brass sender on the bottom of the PTO housing, don't forget to remove it. As I recall it is held in with two 1/4 inch bolts. It makes you mad when you break it.
Total job- 2 hrs.
