VAC Eagle hitch
Tom
11-13-2003 06:55:59
Would like to know what kind of seals are in the lower arm pivot points in the rear end. Mine are dripping oil. I & T manual is not much help. Thanks
Sam#3
11-13-2003 17:50:57
 Re: VAC Eagle hitch in reply to Tom, 11-13-2003 06:55:59
A bit of clearification is needed.
The term 'lower arm pivot points?' Do you mean the lift arms? If so these are pin and sleeves and there's no oil/seals involved. On the other hand if you're refering to the rockshaft then you several posibilties for leaks. 1) The piston seal is leaking into the case and leaking along the shaft on the right side. (The parts manual/catalog shows a seal on the left side.) 2) The release valve has a seal and the control valve has an O ring. These are part of the depth control. All of these leak directly on the right side lift arm.
I advise aquiring a parts catalog. It gives all the details of parts and order of assembly. It can be optained from Case, RIE61, $19.95.
I hope this helps.
