504 specs
Ohio Case
11-12-2003 18:13:26
Ok all you case-wise guys, I am looking for the bore & stroke on the big crank and valve version of the 504.... my I & T book only goes to the 1175. Thanks for your help.
turbo
11-13-2003 18:58:04
 Re: 504 specs in reply to Ohio Case, 11-12-2003 18:13:26
If I remember without looking it up, the 504's in 20 and 2290's had the small rod journal as in a 401-451 engine. The "big engine" had the larger rod journal. Mains the same.
Steve Schmittgens
11-13-2003 13:44:07
Ohio,
Case 504BDT according to my Case engine Spec Manual is: Bore- 4-5/8" Stroke- 5"
This is the Spec for the 1450B Crawler, but, stands true for all 504's.
Steve
Roger
11-12-2003 20:10:39
Not sure what you mean by "big crank & valve version", but my 1370 engine is 4-5/8 x 5.
crazycase
11-13-2003 14:00:02
 Re: Re: 504 specs in reply to Roger, 11-12-2003 20:10:39
all case 504 are same bore and stroke.
