Eagle hitch question
F-I-T
11-11-2003 18:14:47
I apologize up front because I haven't done any research at all. I thought I'd cheat and just ask for the info here!
Is the Eagle hitch considered a Cat.I or Cat.II hitch?
I have mostly Cat.I implements, and wanted to know if I'll need to build any kind of adapter to use them. I'm considering building such an adapter for my JD'70' because it just doesn't let the Cat.I implements go down far enough.
Thanks!
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
turbo
11-11-2003 18:45:16
 Re: Eagle hitch question in reply to F-I-T, 11-11-2003 18:14:47
Cat I
Don Rudolph
11-11-2003 19:42:41
 Re: Re: Eagle hitch question in reply to turbo, 11-11-2003 18:45:16
The Eagle hitch is Category 1. The only trouble you might have is with PTO attachments that are mostly made to mate up with Ford tractors and their very low PTO shafts. This creates a bad angle when attached to the Case high PTO shaft which may cause chattering. Non PTO attachments should work with no or minor alterations.
