Case VA Hydraulic pump
James Butler
11-11-2003 11:24:08
I'm in need of a source to either get the parts to overhaul my Hydraulic pump or somewhere to send it for overhaul. I have the pump that is driven by the cam gear. My VA is a 1944 model. The pump is leaking past the drive shaft seal.
Joe (Wa)
11-11-2003 18:10:47
 Re: Case VA Hydraulic pump in reply to James Butler, 11-11-2003 11:24:08
James, I changed the seal in one of these pumps a few years ago.
Cover gasket (plastic) p/n v20403.
Shaft seal original p/n o4244-ab.
This may be the current p/n a26788.
Bearings are Torrington needle. 4 bearings, 3 different sizes. P/n's are on the cage.
Joe
David811B
11-11-2003 13:30:34
Try Brian at the link at bottom, He seems reasonable
Sam#3
11-11-2003 13:25:12
The parts are available from Case. As things go no more pricy than most.
I had mine done at a Case shop the labor is HIGH.
