Infromation
Bob Harms
11-10-2003 20:32:55
Need to know type and quantity of lubrication for 300 tripl range case tractor.
Joe (Wa)
11-11-2003 22:22:47
 Re: Infromation in reply to Bob Harms, 11-10-2003 20:32:55
Bob, this is from the Case 300, 300b, 400b service manual:
Engine oil ..... 4 qts .....w/filter 5 qts
SAE 30..... .above 70 degs
SAE 20W..... 70 to 32 degs
SAE 10W..... 32 to -20 degs
Air cleaner cup....same as engine
Torque tube w/triple range.....12 qts
SAE 10W....summer & winter
Alternate...hydraulic oil or ATF type A
Transmission:
300 & 310..... 17 qts
301 & 311..... 6 gals
SAE 90 gear oil
This is what I use on my 311b
Engine oil
SAE 30..... ..summer
SAE 10W30.....winter
Air cleaner cup.....same as engine
Torque tube w/triple range.....13 - 14 qts
General purpose tractor hydraulic fluid
Transmission (incl axles)..... 7 gals
SAE 80-90 GL-5 gear oil
Steering gear box...just cover worm gear
SAE 85-140 gear oil Power steering (Barnes pump-CharLynn)....1 qt
ATF Dextron III
Joe
