Replacing copper fuel lines (530CK)
Mike Fallavolli
11-09-2003 22:25:21
I'm having some troubles with old copper fuel lines that start leaking after I've played with them a bit. I'm seriously considering replacing them with flexible hose. Has anyone done this or have a good reason not to? The biggest challenge is of course the fittings. My 530CK has 3/8" line from the tank to the pump and the return line is 5/16". The compression fittings use rubber sleeves. I wonder if just replacing the line with flexible line of the same diameter would work. Would the sleeves seal around the plastic lines?
I should mention, this is the 188 diesel, not gas.
Klyde
11-10-2003 10:03:47
 Re: Replacing copper fuel lines (530CK) in reply to Mike Fallavollita, 11-09-2003 22:25:21
Sombody got there before you. None of those lines were copper, there supposed to be steel.( maybe copper plated) If they have been replaced with copper I don't know how you would keep those eastman rubber compression fittings from leaking. Go buy some brake line the right size and make some new ones, and replace all the sleeves , should last at least another 30 years.
gm
11-10-2003 08:54:29
I cut off near the end of each line (saving the attachment fitting and a bit of copper line) and
attached standard rubber fuel lines with clamps. Makes it much easier to take apart the setup. Also, no bending of the copper fuel lines to fit in place. -Greg
Slowpoke
11-09-2003 23:05:08
Probably not. The copper lines fit inside the sleeves. You won't find fuel hose of the same outside diameter. Hose has much thicker walls than steel or copper tube. You might need to change to ip x barbed hose fittings to use rubber fuel line. Just buy new copper line and replace the old stuff. I've changed my VAC to a steel line with inverted flare fittings. Copper gets banged up and looks bad.
