DC Case water pump
Doug Franks In
11-09-2003 15:39:03
Hey guys, I need a new water pump for a DC, Thought I seen someplace that had reproductions for $85. Cant find them now. Does anyone know where the best priced ones are?? Thanks! Doug
[email protected]
dctom
11-09-2003 15:42:11
 Re: DC Case water pump in reply to Doug Franks In Indiana, 11-09-2003 15:39:03
WHY NOT PUT IN A NEW SEAL IN THE ONE YOU HAVE OR IS IT TOO FAR GONE? DCTOM
Doug
11-09-2003 19:36:04
 Re: Re: DC Case water pump in reply to dctom, 11-09-2003 15:42:11
good idea, but I've never gotten one out of the block without breaking the casting!! Any secrets about Dc water pump removal??? I'm currently spraying a rust remover on it hopeing it will help loosen the pump. Looks like the original one. Thanks Doug
dctom
11-10-2003 06:31:35
 Re: Re: Re: DC Case water pump in reply to Doug, 11-09-2003 19:36:04
DOUG; BEST THING I HAVE FOUND TO USE IS A SLIDE HAMMER, THREAD IT ON THE SHAFT WHERE THE NUT IS AND JUST KEEP BUMPING IT, OTHER THING IS REMOVE NUMBER ONE SLEEVE AND BUMP IT FROM THE INSIDE.
GOOD LUCK TOM
