2290 powershift
harborside
09-16-2006 19:43:24
just got in from baling, was baling in 2/2. I stepped on the clutch, the shifter returned to 1 as it is supposed to, and when i released the clutch i had nothing. I could feel the tractor try to move on 1 and 2 on the powershift, but it didn't go anywhere, but third on the powershift works fine. anyone know where to start looking?
turbo
09-16-2006 21:01:34
 Re: 2290 powershift in reply to harborside, 09-16-2006 19:43:24
If you have reverse, you have a problem with C-1 clutch in the powershift.
SHeiserman
09-16-2006 20:37:44
Can't help you with what may be wrong, but for what it's worth to you, I was always told to move the range selector by hand and not with the clutch. FIL was pretty adamant about that.
Joe-Bob/IN
09-17-2006 09:33:28
 Re: 2290 powershift in reply to SHeiserman, 09-16-2006 20:37:44
I can personally attest that that is not really necessary. I do manually downshift in 4th gear but usually not the other gears. We have 7 Case powershift tractors, all with over 3000 hrs and several with over 6000 hrs and one with over 12000 hrs. Luckily so far only troubles we have had are one 1070 actually wore out the clutch plates, one 1270 and one 1070 sheared off the clutchpack bolts and one currently likes to grind the gears and is slipping going into 3rd. Also have a 2390 that has a hesitation going into 3rd but not slipping, still trying to figure it out. Amazingly the one 1270 with over 12000 hrs has not once had the powershift touched. So, shift them however ya want just try to limit the full load shifts and the high speed clutching while in 3rd.
