SC Seat rubbers??
G. L. Perry
11-09-2003 11:41:42
I have a later model SC seat on my tractor with the bending link and those rubber twist pads on it. I know of these for Olivers from sources, but these appear to be Paired up and need to be molded to the center arm with them. I can cut the outer rivets to get out of link, and bolt back in, BUT, don't see how to get out the center link w/out wrecking it. SO, should I leave it alone and let it bottom out? or do you think Minnkota would anneal new ones on my metal? They always ask for cores, so thinking they could do any type core?? I can't be only guy in world who wants these fixed?? What have you fellas with them done? My other choice is too go to springs and bolts like orig had?? I don't think my base plate has the place on it for the spring? Do these work? Or do they get weak too, and won't be any good ones out in world?
Scott KY
11-09-2003 15:10:54
 Re: SC Seat rubbers?? in reply to G. L. Perry, 11-09-2003 11:41:42
Minnkota should be able to fix you up. They did one for me for a 400. Send in your old one and they will send you a new one. It makes a lot better seat than the spring type.
