More SC questions-throttle rod?
G. L. Perry
11-09-2003 11:35:23
Got the hub bearing and in, thanks for number. The gas tank pad was just a thick felt, after I cleaned it up. Guess anything will work.
NOW, I need to fix my choke rod. What was wrong with a cable, sheesh? Why is the carb on wrong side of engine and controls on other, sheesh? Anyway, is the rod mostly straight? Mine is all bent up. I don't recall how I took off, I know it came off with my dash, as I couldn't get it out of it. I have since cut it out and ruined the brassy part that bolts to dash. I don't see how to get it off the rod with all the bends in it. SO, is there anyone with another?? Is there a diff fix?? I found holes under batt box where I think it goes, but can't get it into second hole nearer engine with bends I have. I don't recall how it hooks to carb either?? I have this little rod about 6" long with loop in end and thinking that may have been on carb and used nuts on rod end? Is this right? I can't find a picture in any of my parts/owner's/IT books showing this. I got the throttle figured out with a pix or two finally! I have that small rod in upper hole on choke lever, must need to be in lower? to pull against spring on lever? Is there any other thing to hold choke open when pulled? Guess I can't recall how things go back together as easy as I once could, need pictures to save as I go!!
John Saeli
11-09-2003 18:21:05
 Re: More SC questions-throttle rod? in reply to G. L. Perry, 11-09-2003 11:35:23
Hey Gary; I sent you an e-mail this afternoon, but I got a reply back that says it is undeliverable for now, but it is still trying to send. Let me know if you get it. I have neither items but had a suggestion.
G. L. Perry
11-09-2003 22:41:38
 Re: Re: More SC questions-throttle rod? in reply to John Saeli, 11-09-2003 18:21:05
John, maybe that's why I'm not getting much email today, it's broke?? I've been getting the Spam, ut not much! Try my Yahoo mail at [email protected] and I'll see it it works. My server has been having more trouble last month and they DO stop most of my Yahoo lists from coming because of spam on them. I now use there mail site for those lists. Maybe it was a trick?
