DC transmission
Scott KY
11-09-2003 08:23:44
When shifting out of reverse on my DC, the shift lever will come into the neutral position but the tractor remains in reverse. After several times shifting the lever in and out of neutral the tractor will remain in neutral. It tends to do the same thing in second gear which is directly across from reverse on the same shaft. Anyone have ideas what to look for when I pull the transmission cover off?
Don Rudolph
11-09-2003 09:42:15
 Re: DC transmission in reply to Scott KY, 11-09-2003 08:23:44
Sounds like the tip of your shifting lever is worn or broken off or the slot in your shifting blocks is worn badly. Should not be too hard to fix.
