Looking at a David Brown 880 w/Loader
David Donaldson
11-07-2003 12:44:25
Gentleman, I am looking at buying a tractor to replace my Ford 800. One of the current front runners is a David Brown 880 with a quick connect loader.
What do I need to know about this machine?
randy
11-08-2003 20:06:26
 Re: Looking at a David Brown 880 w/Loader in reply to David Donaldson, 11-07-2003 12:44:25
hey david i got a friend that has a 990 david brown with a case hydraulic loader with new tires and it also has just been repainted and new crank and bearings put in about 3 hours ago email if you'd be interested
scott
11-10-2003 12:11:34
 Re: Re: Looking at a David Brown 880 w/Loader in reply to randy, 11-08-2003 20:06:26
yes i am kind of interest how much and where are you located
randy martin
11-10-2003 16:44:32
 Re: Re: Re: Looking at a David Brown 880 w/Loader in reply to scott, 11-10-2003 12:11:34
hey we are in schleswig iowa and you can call my friend that has it at 1712-676-3482 during the day and his name is donny
thanks
john
11-08-2003 06:50:15
Make sure you can get parts. A Case-IH dealer should be able to get them. We had a 990 at work. The P.S. pump started leaking and had to buy a new style as parts weren't made for the orginal any more. Big $$$$. Other than that a very good tractor.
Irv Plitzuweit
11-08-2003 06:36:11
I have owned a David Brown 770 for over 25 years. It is a 3 cylinder diesel, with 12 forward speeds, and 4 reverse. Has live pto and hyrdalics with a 2 stage clutch. Very good tractor for me, The only repair was clutch replacement, and now it need brake linings replaced, which appears to be a big job. I have to take off loader and rear wheels I think. I put a block heater in it and it starts easily in below zero weather.
Elmer
11-08-2003 07:09:29
 Re: Re: Looking at a David Brown 880 w/Loader in reply to Irv Plitzuweit, 11-08-2003 06:36:11
When you replace the brake lining be careful where you buy them. There was some bad linings on the market. I just went through some.
Elmer
11-07-2003 14:24:19
Need a little more info. The 880 started production in 1961 and went to 1970. There were three different 880's built. Is it a white or red one. Does it say Implematic or Selectamatic on the hood. There were two different Implematic's, one had three cylinder diesel and the other a four cylinder diesel. There was also a David Brown 880 Diesel on the one tractor slated for the U.S.A. only in 1965 which is a rare one.
James
11-07-2003 18:32:47
 Re: Re: Looking at a David Brown 880 w/Loader in reply to Elmer, 11-07-2003 14:24:19
I'm sure they are all better than the 800.
Elmer
11-07-2003 18:56:25
 Re: Re: Re: Looking at a David Brown 880 w/Loader in reply to James, 11-07-2003 18:32:47
I have only seen literature on the 800. Never came across one yet. Did you have one?
steveormary
11-07-2003 20:28:15
 Re: Re: Re: Re: Looking at a David Brown 880 w/Loa in reply to Elmer, 11-07-2003 18:56:25
I did that once. Sold the 800 at auction and started looking for a replacement. Ended up with a Farmall 300. Should have kept the 800.
