Case magneto
Scott KY
11-06-2003 18:43:32
A case DC uses a CMA magneto and an SC uses a JMA magneto. Will either mag work on either tractor? What is the difference in the two mags?
Mike Schotte
11-06-2003 19:13:37
 Re: Case magneto in reply to Scott KY, 11-06-2003 18:43:32
Only the early DC tractors used the base mount magneto (4-CMA). This was prior to Tractor No. 4607033 - (1942 production.)
The later DC tractors used the 4-JMA flange mounted magneto.
There were different governor assemblies that went with the different magneto types.
I don't have any experience doing so- but I'm pretty sure they are a bolt-on swap for each other.
-Schotte
One more thing...
11-06-2003 19:17:38
 Re: Re: Case magneto in reply to Mike Schotte, 11-06-2003 19:13:37
To address the rest of your question-
To my knowledge- there was never a base mount magneto option on the Case SC. They always had a flange type magneto. Edison-Splitdorf for the first year or so, type 4-JMA for most of the run and Type 41 mag for the later years.
-Schotte
Scott KY
11-07-2003 04:24:59
 Re: Re: Re: Case magneto in reply to One more thing..., 11-06-2003 19:17:38
Thanks for the info!
Scott
Glen in TX
11-07-2003 14:53:53
 Re: Re: Re: Re: Case magneto in reply to Scott KY, 11-07-2003 04:24:59
Scott, Mike is right on the mags. My mag books show no evidence of a SC ever using a base mt. mag. The mag impulse should have been set up at 25 degrees for both late D, DC, and all S, SC series and same rotation so no problem to interchange. All V series mags required a 15 degree impulse. The impulse can be reset or changed for different applications to interchange.
