930 drawbar mounting bolts (up undderneath the tra
R Wyler
11-06-2003 14:59:56
I took the draw bar off my 930 and had it built up as it was nearly worn through. Anyhow it had two 5/8 bolts holding the mounting bracket on and the holes are 3/4 inch. If they are suppose to be threaded there is very little threads left in the holes. I figured at first that is was suppose to have fine thread SAE bolts with nuts I bought a couple today and they will ony go in so far. It looks like it could have what is left of course thread's in it if so they are wollered out it looks like they might have had a dozer blade on it. So my querstion is this, what kind of bolts are supposse to be in it SAE fine thread or National course thread? And was it originally cap screws or did they have nuts? Thanks guys for any help as I really need to get it back together. R Wyler.
case931
11-07-2003 08:33:34
 Re: 930 drawbar mounting bolts (up undderneath the in reply to R Wyler, 11-06-2003 14:59:56
Mine is off the tractor. I will look at it when I get home about 5pm central time. Will also look on parts CD to check size and style. Mine is '67 model, btw.
R Wyler
11-07-2003 09:24:04
 Re: Re: 930 drawbar mounting bolts (up undderneath in reply to case931, 11-07-2003 08:33:34
Thanks case 931 mine is a 64 model. R Wyler
case931
11-07-2003 20:02:53
 Re: Re: Re: 930 drawbar mounting bolts (up unddern in reply to R Wyler, 11-07-2003 09:24:04
Case 930 Comfort King 1962-1964 shows bracket bolts to be 2 each - 5/8" X 2 1/2" Nat'l Fine with lock washers and nuts. Bolts come through from under side of bracket with nuts and washers on top. Hope this helps.
R Wyler
11-07-2003 20:17:53
 Re: Re: Re: Re: 930 drawbar mounting bolts (up und in reply to case931, 11-07-2003 20:02:53
Thanks Case931 I taped them out today and was able to get 3/4 natl fine thread bolts in it I bought 2 1/4 I need 2 1/2 so I can use lock washers. Thank you again for the help as I like to know how it is suppose to be. R Wyler
