Case VAI
Jerry
11-06-2003 03:39:28
I am looking at a 1950 industrial tractor in good condition to purchase. the owner says it is in the original colors of white and yellow. Is this color combination correct? What RPM will the Pto run at? What is a fair price for this machine?
Thank you for any help.
Jerry
Art
11-07-2003 03:55:16
 Re: Case VAI in reply to Jerry, 11-06-2003 03:39:28
Hi Jerry, I have a 46 VAI, also painted the wrong color...should be "Flamebau Red". Also a a VA series motor run at 1425 rpms at full throttle where as a VAI run at 1950 rpms. The pto turns at 540 rpms at 1425 rpms....That means that if you have an implement that can be damaged at speeds above 540 rpm, you just have to throttle back to 1425 rpm... on the other hand, if the implement can handle the extra speed, you can get done w/ your work a little faster...But be careful running an implement faster than it was designed for as damage to you,the tractor ,or the implement could result...Good luck Art
