Case 530CK backhoe with low clutch pressure
Gary
11-05-2003 16:42:14
I have over 220 psi coming out of the filter. I have 30psi on the dash gauge with the clutch out. When I push the clutch in I have 42 psi. I just finished cleaning and installing new springs in the spooler valve assy. No help. This problem started after I replaced the filter and the fluid. At first I had 100 psi, and week or so later 90 and eventually I'm down to 30. The local dealer thinks that I have some internal leaking causing the problem??? Anyone have a thought? Could it be the torque converter? If it is, can it be rebuilt/new one?
Thanks for your time..Gary
Steve Schmittgens
11-06-2003 12:45:58
 Re: Case 530CK backhoe with low clutch pressure in reply to Gary, 11-05-2003 16:42:14
Gary,
I might be able to provide you with some help. Feel free to call me @ my shop, the No. is (314) 966-6692.
Steve
