VAC Project: Need some rear tread dimensions
F-I-T
11-05-2003 16:24:21
Well, my Flambeau Red paint turned out really nice on my rear axles, and I really don't want to scratch it any more than I have to, so I heed some help from a fellow VAC owner.
I have 12.4/28's on 11 inch rims. What I would like to know is:
Your tractor centerline to the outside of your tire, and how much axle end is sticking out. If I have your tire size it will help. I'm trying to pre-set the wheel hubs on the axles so that I have an overall dimension of 72" (or a bit less), so that my 6 1/2 foot disk will fit the tread.
I figured if I'm careful, I may not have to move them after final painting.
Of course then I"ll find a plow and then all bets are off!
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
1950CaseVac
11-06-2003 16:56:29
 Re: VAC Project: Need some rear tread dimensions in reply to F-I-T, 11-05-2003 16:24:21
Frank,
I also have 12.4-28 tires, but the rims are 10" (I don't think Case had an 11"-28 rim). Anyway, I have my tires 60" on center (which is close to 72" outside tire width). There's about 2" of axle exposed on each side. Wheel hubs are mounted concave side facing inward, which is the typical way to mount the wheels unless a wide stance is needed. I hope this is what you were looking for.
F-I-T
11-06-2003 20:56:55
 Re: Re: VAC Project: Need some rear tread dimensio in reply to 1950CaseVac, 11-06-2003 16:56:29
Yes! That helps a great deal. I have 10 rims, too. I measured them today.
I think I might have longer axles, though. Brandon says his axles stick out 11" from the end of the housing. Mine are 14".
Frank
Brandon
11-05-2003 18:30:43
If it will do any good, with our '49 VAC:
Hubs set wide, rims set narrow, 10x28 tires.
Tractor Centerline to outside of tire: 35 1/2 inches
Axle sticking out of hub: 3 3/4 inches
Distance between inside of hub and axle housing: 3/8 inch
Brandon
My Industrial John Deere website
My JD model 80 website
The LaGrange Engine Club
F-I-T
11-05-2003 19:42:21
 Re: Re: VAC Project: Need some rear tread dimensio in reply to Brandon, 11-05-2003 18:30:43
Brandon:
Thanks!
A couple questiions:
~~Hubs set wide: do you mean that the "dome" is outward? (that's the way I want to set mine)
~~rims set narrow: do you mean the single bevel is on the outside?
BTW, my axles stick out 14" from the end of the axle housing. I'm guessing it is 25" to the centerline from the housing end, so the axles are ~59" long?
Frank
Brandon
11-06-2003 15:38:31
 Re: Re: Re: VAC Project: Need some rear tread dime in reply to F-I-T, 11-05-2003 19:42:21
Yes the single bevel on our rims is on the outside. Actually there is not a bevel all the way around, but four bulged spots to hold the wedges in place.
Here is a picture that shows which way our hubs are dished:
Some rough measurements:
Axle length sticking out of housing: 11 inches
Centerline to end of axle housing is 25-26 inches.
Having fun yet?
Brandon
Wheat Straw
11-05-2003 18:24:55
Frank,
There were different length axils on the VAC's. Make sure you get the axil length on the #'s someone gives you. I think I understand what your wanting to do. Sounds like you want to just move it in on the axil so far and clamp it down. Axils differ in length and rims can be mounted at different mounting points. You may be set up different than someone else is.
Good luck
Wheat Straw
F-I-T
11-05-2003 19:46:17
 Re: Re: VAC Project: Need some rear tread dimensio in reply to Wheat Straw, 11-05-2003 18:24:55
Wheat:
Thanks for the good thought. My axles stick out 14" from housing end, and my measuring in the dark gets 59" from axle tip to centerline. Does this sound like a good number? Per the parts book, it would adjust from 44" to 88".
Frank
GeoMo
11-06-2003 06:42:17
 Re: Re: Re: VAC Project: Need some rear tread dime in reply to F-I-T, 11-05-2003 19:46:17
I have the dome out but set the hub to the end of axle, wide as I can get in the narrow direction. I had the right side set in for plowing and turned mine over when mowing a bank.
I then set wheels out and offset plow, may pull sideways a little more.
I do not know what tread with is but you can also set rim of opposite side of hub.
