311B
Russell
11-05-2003 15:07:42
What to set the timing at? Thanks
Joe (Wa)
11-05-2003 18:19:33
 Re: 311B in reply to Russell, 11-05-2003 15:07:42
Russel, you may find IGN and DC on the flywheel of the later 311B (I have a '59). DC is #1 piston TDC and IGN is distributor timing 4 deg before TDC. I do a rough setting to plant the distributor and then a fine adjustment at idle with a timing light. Joe
JohnM
11-06-2003 05:21:16
 Re: Re: 311B in reply to Joe (Wa), 11-05-2003 18:19:33
You guys are lucky. I am trying to time 411B with a timing light and all I can see is the oil splashing around the pointer!
Lincoln
11-05-2003 16:44:29
I&T book says to turn it over untl #1 cylinder is on compression stroke. The fly wheel DC mark should be 7/32 of an inch before the pointer and adjust distributor so the points are just starting to open.
