automobile power steering pump to use with Behlens
aaron
11-05-2003 10:03:37
I am learing how to piece together a power steering setup for an H Farmall.
I have access to a Behlens motor. It will hook into the Belly Pump but will not be live with the cluth disengaged. So, I learned that a fella could go to a auto salvage yard and choose a power steering pump driven off the fan belt to be the power source and reservoir for the Behlens unit. Any ideas on what I should look for. i.e. F150 pump, Mazda pump, ...
C. Amick
11-05-2003 14:01:28
 Re: automobile power steering pump to use with Beh in reply to aaron, 11-05-2003 10:03:37
I saw a power steering unit advertised somewhere that inserts into your steering shaft. Of course, you have to cut a section out of your steering shaft to install it. I would think that most any kind of power steering pump or hydraulic pump that you can run with a belt from your engine would work with it
