DO lights
chuck ore
11-04-2003 08:46:52
Took the lights off of my DO to get them going O f course the first thing I did is to breack the bulb and the other light has no bulb in it.The bulb was a 12 volt and had a coller around the base with 3 sloted holes to turn the bulb out anybody know about these ?Thanks Chuck ore.
Baggsy-Wy
11-04-2003 12:57:35
 Re: DO lights in reply to chuck ore, 11-04-2003 08:46:52
The 7 inch lights on the "D" series had the bulb with the collar and three slots...with a spring loaded affair that they fed into to hold the bulb tight. I had a whole box of those bulbs, but only have a couple left now. But all those I have run across were six volt. I'm not sure what the 12 volt part number would be. Seems like mine are 2330's or something like that. Here's some dual filaments on e-bay, and they can be made to work by soldering a piece of wire between the two contacts, and are a bit brighter as both filaments are lit up at once. I'll do some looking and see if I can find a 12 volt version of them...
Mike Schotte
11-04-2003 08:57:36
Chuck,
I will humbly refer you to a previous lighting/bulb post by Baggsy... "the master" of all Case/Guide lighting questions (IMHO).
-Schotte
