How much should I pay for a 4890??
John Saeli
11-03-2003 18:20:02
Hey Men!! 30.5X32 12ply Stomil Radials, 98%. 300 hours on a major engine & Power Shift Overhaul. 4500 Total tractor hours. 3PT. Hitch. Interior needs new foam kit. What's she worth??
Gess who John
11-04-2003 22:02:54
 Re: How much should I pay for a 4890?? in reply to John Saeli, 11-03-2003 18:20:02
The tires are no good with out Duals, They will do the Power Hop as singels, there is a guy in Slaterville that has on the is equiped this way ,has singels. our 2870 used to do it before we put duals on it.20.8 34's .the rears don't have the lockers like the 2470/2670's 4490-4690's have,there open.we pull 7-18's most conditions in 3-3 and 3-2 /3-3 with 32 Ft amco disk /with eather 2870 or the 4890 . the brake system is a dry type like your 870 [buy larger] they don't stop the best.my cusin has a 4890 he pulls a 10-18 plow in Lansing.
Glen in TX
11-03-2003 23:55:17
Check the rest out too. Axle and differential repairs on them can get expensive in a hurry. It is 20+ years old now. 18.4 duals will ride better. Those big tires like to bounce on rough ground but work ok on flat ground if you don't get in a hurry. 10K to 18K.
John Saeli
11-04-2003 04:52:17
 Re: Re: How much should I pay for a 4890?? in reply to Glen in TX, 11-03-2003 23:55:17
Hey Glenn; Didn't see or hear anything obvious. Driveline is heavier than what is on my 4690. Been troublefree on the 4690. Any weak spots on the 4890??
Glen in TX
11-04-2003 09:23:09
 Re: Re: Re: How much should I pay for a 4890?? in reply to John Saeli, 11-04-2003 04:52:17
John, Was just meant as word of caution. Hate to see someone else get stuck with a big repair bill on another 4890 like neighbor did this summer. I don't really know of any major weak spots. It really depends on how well kept it was and how hard you plan to run it. He is doing custom plowing with his and tried to grab another gear to catch up after rains before putting in wheat. The guys he bought it from are well known for keeping their machinery in A1. It was just too hot yet to be doing that and he got engine hot and had to replace heads, water pump, and then tore the rear end up but was asking for it going too fast with 40' big sweeps in tight ground. Just ask more questions if you don't know owners or pop in at a local shop that did maintainance on it and quiz a mechanic to be safe. Good luck.
Bill N
11-03-2003 18:26:03
Seen them go for $15,000 at auctions but not with a new engine and tires. $20,000 sound like the upper limit. 4490's are a lot more common. 48's will get a lot of work done in a hurry.
