VAC Adj WFE
Tom
11-03-2003 13:58:12
Looking for a source for a detailed drawing/illustration of the parts in an adj WFE. Have onw I'm installing but lack bolster shaft and vertical shaft that does the turning. I&T Manual is disappointing at best.
Joe (Wa)
11-04-2003 17:13:47
 Re: VAC Adj WFE in reply to Tom, 11-03-2003 13:58:12
Hi Tom & Frank,
Not to confuse the issue but that page in parts manual E61 lists the vertical shaft p/n VT4153 as opposed to VT4135 in Frank's D61 manual.
The other numbers associated with the shaft match up. Looks like the last two digits may have been switched.
VT4153 appears to cross to A29398 but you would have to run that by a Case dealer to confirm.
Joe
F-I-T
11-04-2003 18:46:32
 Re: Re: VAC Adj WFE in reply to Joe (Wa), 11-04-2003 17:13:47
Joe:
Looks it was a typo in the illustraion. In the parts breakdown, it is listed as VT-4153.
Frank
F-I-T
11-03-2003 18:34:26
third party image
Tom:
Not sure if this the one you need. Let me know if you need something different.
Sorry for the supersized image.
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
Tom
11-04-2003 06:27:14
 Re: Re: VAC Adj WFE in reply to F-I-T, 11-03-2003 18:34:26
Thanks for the diagram! Looks like the only hard part will be finding #VT-4135 verticle shaft. Everything else I can make or pirate from the narrow front.
F-I-T
11-04-2003 08:21:56
 Re: Re: Re: VAC Adj WFE in reply to Tom, 11-04-2003 06:27:14
Tom:
I just had my front end pedestal apart, and the "regular" shaft seems pretty soft. You might be able to take one of those and have a lathe guy cut to length, turn the taper, turn on a stub, thread it, and the put mill in a keyway. Basically shorten a regular shaft. Not having seen one, I can only guess that the ends are alike, just one shaft is longer.
Frank
Tom
11-04-2003 15:58:20
 Re: Re: Re: Re: VAC Adj WFE in reply to F-I-T, 11-04-2003 08:21:56
F-I-T, Thats what i thought. All I would need is the dimensions, since my dad is retired tool & die maker.
