1941 SC Case
Larry A. Lamp
11-02-2003 13:59:15
I have a '41 SC with a severly cracked block. I was reading below the "41 did not have side ribs on the engine. Mine does and the SR# on the engine matches the SR# plate on the dash. It is not center exhaust either. I am looking for a block for it so I can restore it. I love the big fenders and straight cast rear wheels. What was the rear rim width on this year?
Don H
11-03-2003 08:51:13
 Re: 1941 SC Case in reply to Larry A. Lamp, 11-02-2003 13:59:15
Larry, I may be able to help you out with a 41 block & matching serial number plate. Email me at [email protected]
dctom
11-02-2003 16:04:45
not all 41 SC's were smooth block didnt make very many of them or center exhaust, didnt take themlong to see that the front end would break off with out the ribbs,
Mike Schotte
11-02-2003 14:23:04
Hello again, Larry.
Not sure what year/serial number that they changed the smooth block to the ribbed block- they may say in "Full Steam Ahead"... I'll poke around later and look for it. You probably just have a tractor made after the production change over.
I've got an early 1941 SC parts catalog, and it lists either a 8.00-38 rim or a 9.00-38 rim being available for the SC.
-S.
Bill
11-02-2003 14:44:33
 Re: Re: 1941 SC Case in reply to Mike Schotte, 11-02-2003 14:23:04
Hi, i have a s c case that has a real crack in the block, but sleeves and rest of block looks great. I have a guy that fixes anything and he looked at it and told me he would fix it right and put j. b. weld over after. Claimes this is the best way to do it As long as cracks are not between cyls.
