battery not charging
case431
11-02-2003 09:02:39
I am helping work on a Case 431 diesel. The genertor is not charging the battery. The gen. has two posts and the regulator has three posts. Could anyone tell me how these are wired-up? Checking the gen with motor running there is no voltage on either post on the generator. Thanks
kgb
John Saeli
11-02-2003 19:12:27
 Re: battery not charging in reply to case431, 11-02-2003 09:02:39
Hey CASE 431; The reg posts are: "Field" going to gen, "ARM" going to gen, and "BAT" coming from that "GEN" lite. If the bulb is blown in that lite, the generator doesn't charge. Hope this helps.
case431
11-03-2003 03:02:48
 Re: Re: battery not charging in reply to John Saeli, 11-02-2003 19:12:27
Hey John,
Thanks for the reply. There is no bulb in the light, it's missing! Would you know what bulb I could put in it to get it working?
Thanks again,
kgb
John Saeli
11-03-2003 18:16:03
 Re: Re: Re: battery not charging in reply to case431, 11-03-2003 03:02:48
Hey case431; I don;t remember having one out, but you should be able to match one up to the base. Base size & ear placement. Good luck.
