SC case
Mike Schwartz
11-02-2003 02:00:57
Spent the day going and getting the '49 SC and then I worked on it for a while. Found a few things wrong. The radiator cap is missing, is there a newer replacement or do I need to look for the cast cap? The brake lining on the clutch/belt pulley is worn out is a replacement available or will any brake lining work? Where do you check the level of the oil in the rearend tranny? at the plug on the PTO housing? Finally got the rear wheels broke free and moved in but had no luck with the front end. The hollow tube part of the tie rod ends has rusted and been bent to many times. Are replacements available or has anyone had any luck making new ones? Last question for now has to do with the ring gear, can it be reversed or does it need to be replaced, starter was not installed correctly in the past and the teeth are pretty badly ground off. Thanks for your input, After looking the tractor over today I think that I will completely restore the '41 and restore the '49 as a good working tractor, MIke S (WA)
caseman-d
11-02-2003 09:01:10
 Re: SC case in reply to Mike Schwartz, 11-02-2003 02:00:57
The part number for the cap is still a good number. If I remember it's like 65.00. For that price it should be original.
caseman-d
