267 Diesel cracked heads - Replace or repair ??
Rollin
11-01-2003 14:26:53
Pulled off the A267 Diesel Heads ( in a 730 ) and found 3 cracks between the valves in the chamber. After reading the archives, I discovered this is common on the 267. Anyhow, whats the best fix? Have them welded or go for boneyard replacements? Thanks in advace for any help.. Rollin
Roger
11-01-2003 21:57:06
 Re: 267 Diesel cracked heads - Replace or repair ? in reply to Rollin, 11-01-2003 14:26:53
Midwest cylinder head in Nevada Iowa does a damn good job.
DON L
11-02-2003 07:14:31
 Re: Re: 267 Diesel cracked heads - Replace or repa in reply to Roger, 11-01-2003 21:57:06
seems all the head repair shops went up, Neveda got $400.00 from me to redo a DC head . I went to a guy in ILL and it to was $400.00 again. And that was suppose to be with a account discount. I repaired some LP heads{ 6128A }for DC's. Then add up the shipping both ways on 80 lbs. I found another man that will weld them for $250.00 plus ship , so I may go that route next time.
keith
11-01-2003 16:59:16
I had one of my heads welded for my 730 It was cheaper than getting a replacement good heads are expensive.
John Saeli
11-01-2003 16:49:46
Hey Rollin; 2 things crack those heads; Either & overheating. Head welding is becomming a lost art. If you are close to George in Md(He's on this board) have George look @ them. If you can easily have them welded, that's the way I'd go.
Elmer
11-01-2003 16:58:34
 Re: Re: 267 Diesel cracked heads - Replace or repa in reply to John Saeli, 11-01-2003 16:49:46
There is a really good place in Montreal that repairs heads. I have had really good luck with them. Their is a place in Mississauga Ont. that is good but they're deadly expensive.
