Case SC
Mike Schwartz
11-01-2003 10:13:05
Hello, Last year I acquired a '41 SC tractor that I was going to restore. This past week I found another SC, a '49. Both are running tractors but I plan to put all of the best tin and tires etc. on one tractor. My question is is one of the tractors more desirable than the other? From a collectability standpoint or from a useability standpoint? Both have adjustable wide front axles. The '49 has a oil filter, both have mechanical lift and Pto but no hydraulics, can Hyd be added to these tractors? Tractors are not for sale, just looking for info so as to not degrade the value of the possibly better tractor. I am planning to restore one while making a good working tractor out of the other one. Thanks Mike S.(WA)
dctom42
11-01-2003 13:56:45
 Re: Case SC in reply to Mike Schwartz, 11-01-2003 10:13:05
I would use the 49 for my work tractor, i know the hydralic from a newer one would fit right on it, you would need pto shaft and hyd, unit from a 50 or 51, the 41 is first year for them dctom
old
11-01-2003 10:41:22
I can't tell you which one is better but if I had them I'd restore the 41 and work the 49 for two reasons since the 41 doesn't have an oil filter on it and since its older I'd restore it and because the 49 has the oil filter and is newer I'd use it for the work horse. But that is my way of thinking hope this helps you any way have fun with them
Joel Shelton
11-01-2003 19:00:07
 Re: Re: Case SC in reply to old, 11-01-2003 10:41:22
I agree I would go for restoring the 1941. If you do restore the 41 be sure to at least use the hood on it since I believe it has the exhaust thru the hood and the 49 did not. a 49 hood on a 41 serial number tractor may raise a flag for some nitpickers.
Joel
John H-WI
11-01-2003 19:43:00
 Re: Re: Re: Case SC in reply to Joel Shelton, 11-01-2003 19:00:07
The 41 should also have the chrome strip plus they are different in the 41 hood was wider on the sides also and the block didn't have the ribs. If the 41 has the center exhaust its more unique.
