Case CC, valves and manifold
Jack
10-29-2003 16:25:23
I am restoring a Case CC,a few of the valve seats are junk and some of the valves are pited. Are parts still avalible? Does anyone have the specs?What can I do? I also need a manifold, The old duel fuel is beond welding. Does someone make a new replacment? I also need a cast center for a rear wheel. Someone from the Dakotas responded last month, Sorry I lost the email you sent me.
DKase
10-30-2003 10:09:48
 Re: Case CC, valves and manifold in reply to Jack, 10-29-2003 16:25:23
I might be the guy that emailed you about the wheels. I still have them. Freight will be the biggest consideration. I am in Eastern SD. You might be able to find a set closer to home that would be better for you. Let me know if I can help. I have quite a bit of CC stuff. DKase
Darrell
10-29-2003 22:19:42
Jack, I restored a CC and have quite a few parts leftover, also have several parts DC's and a lot of parts interchange. I have a set of CC cast rear wheels in good shape, I also may have a hot manifold off a DC that would fit and is in good shape. I have a CC head that I was going to use (used a 5508 head instead) but it is all cleaned up and seats ground, you would need valves and guides. I found valves and guides that will work from automotive cross reference, much cheaper than Case. I live in North Central Nebraska, drop me an e-mail if you are interested. I will find out exactly what the reference was for the valves and guides if you want also.
Darrell
10-31-2003 08:43:24
 Re: Re: Case CC, valves and manifold in reply to Darrell, 10-29-2003 22:19:42
Sorry guys...I was mistaken about a automotive cross reference for the CC valves. Talked to the guy who helped me with the head and we found only the guides from an automotive source (and the O.D. needed to be turned down slightly to fit.)
dctom
10-29-2003 16:55:41
same parts as a DC good head rebuilder can get them also a dc gas manifold will work hot manafold hard to come by other than 500.00 new one dctom
