Case Model DO value
Chuck Ore.
10-29-2003 07:25:27
I just found a case model DO up in the brush .I brought it home and after a few hours got it running .It has the operator fairing on it with standard fenders,hand clutch,good rear rubber and all the original gauges work.I collect IHC orchards and have no idea what this beast might be worth.I think this tractor would give an OS4 Mccormick a good run for it's money.Thanks Chuck Ore.
Brian Case
10-30-2003 08:44:44
 Re: Case Model DO value in reply to Chuck Ore., 10-29-2003 07:25:27
Chuck
Please send me your email address. I have a number of questions about the the mounting brackets on the DO. Where are you located?
Thanks
BC
chuck ore.
10-30-2003 09:49:10
 Re: Re: Case Model DO value in reply to Brian Case, 10-30-2003 08:44:44
the lights on this tractor mount on a cross brace that goes across just in front if the cowl,looks OK but not sure if it,s correct.I would guess the under the raditor mounting would be good that's how my Mccormick orchard mounts. I'am in Hoodriver OR.
dctom
10-30-2003 09:31:35
Which brackets? head lite brackets ar at bottom of radiator shell dctom
dctom
10-29-2003 07:53:01
Chuck, i have seen them sell for from 4500.00 to 5500.00. the DO would compare with your O6 in the international line tom
