Case toplink/generic toplink differences
david
10-28-2003 13:58:55
What is the difference between an Original Case topling and the ones for sale everywhere??
about 75 dollars
10-29-2003 17:16:44
 Re: Case toplink/generic toplink differences in reply to david, 10-28-2003 13:58:55
Isn't the top hole on the Case 1 inch where the "standard" is 7/8 inch? Is the Case maybe a couple of inches shorter? Would have to go look to be shure. Of course much better quality.
Gene Dotson
10-30-2003 02:11:45
 Re: Re: Case toplink/generic toplink differences in reply to about 75 dollars, 10-29-2003 17:16:44
The Case link is shorter than generic one. Both have 3/4 inch holes. Cannot use the generic link with the plow on my 700 as it is too long. Also the generic one is thicker at the ball and must be ground down to fit in the upper mount... Gene
Dave Beiter
11-03-2003 09:02:58
 Re: Re: Re: Case toplink/generic toplink differenc in reply to Gene Dotson, 10-30-2003 02:11:45
75 dollars is correct... At least for Rock Island tractors. The top (tractor) side is 1 1/8" as compared to 3/4" and the implement side is standard 3/4" The Case top link is also shorter. For Racine tractors like your 700B the Case is shorter and does have the offsets you talk about. BUT there was a longer top link offered by Case for the Racine tractors. I have both, you use the shorter model for plows etc (with the PTO Cover on) and the longer one from the mount on top, near the seat.
Gene Dotson
10-29-2003 06:34:18
David;; The top link for my 700 is offset on the ends to clear the hydraulic levers. If I use a generic top link, I have to be very careful about clearance when I lower the lift... Gene
David
10-29-2003 08:26:16
 Re: Re: Case toplink/generic toplink differences in reply to Gene Dotson, 10-29-2003 06:34:18
Don't suppose you have a picture of that on the tractor??
Gene Dotson
10-29-2003 15:59:05
 Re: Re: Re: Case toplink/generic toplink differenc in reply to David, 10-29-2003 08:26:16
I will try to get a picture of it tomorrow. It is on the tractor now... Send me your e-mail address...Gene.. [email protected]
case poor in pa
10-29-2003 06:11:26
i think the diffrence is that them case toplinks are made to last forever. them hopsing toplinks arnt worth a hoot.them chinamen cant make a good one that the threads wont pull out. at least you dont see many used ones at the auctions that aint junk.. besides them chicom links dont have an eagle on em..
Marc
10-28-2003 15:52:56
Price? :)
