STORING TRACTOR FOR WINTER.
JAMES TAYLOR
10-28-2003 05:35:22
I AM GOING TO BE STORING MY TRACTOR AWAY FOR THE WINTER, A NEIGHBOUR TOLD TO PUT WOOD UNDER TIRES TO KEEP THEM OFF GROUND,(JUST FLAT BOARDS, THE WEIGHT WILL STILL BE ON THEM) TIRES ARE LOADED WITH CALCIUM. HE SAYS THIS HELPS TO PREVENT TIRE FATIGUE. WILL BE SITTING ABOUT 5 TO 6 MONTHS, IT WILL BE STORED IN A SHED WITH A DIRT FLOOR. JUST WONDERING WHAT OTHER PEOPLE THINK ABOUT?
John
10-29-2003 08:23:37
 Re: STORING TRACTOR FOR WINTER. in reply to JAMES TAYLOR, 10-28-2003 05:35:22
25 years of experiance with my VAC says "sta-bil and park it" never had a problem with it and it always starts right up in the spring. more recently i have started filling up the gas to prevent corrosion.
putting boards under the wheels is debatable. it keeps the tires away from the moisture on the ground, but it also concentates the weight of the tractor on the tire treads. if you were to park on graval or sand, the tires sink in a little bit and it helps distribute the weight evenly. I personally park my tractor on the gravel floor of my barn, and have never had any problems with the tires, which are the same ones that came on it 25 years ago.
SmartAxe
10-28-2003 09:04:12
If it's a gas unit, use Sta-Bil in the fuel. Sta-Bil is some good stuff, just follow the directions on the bottle for mixing it, and run the engine for a while to make sure it gets through the fuel lines to the carb. Also, a full tank of fuel won't form condensation and as a result won't rust the inside of the tank. A lot of people don't like this idea as they say fuel goes "stale" over the winter(and they don't want to "waste" a full tank of gas), but the Sta-Bil will stabilize the gas and keep it from going stale or turning to "varnish" in the carb. Just my thoughts, though, other guys have different opinions. You may want to check the archives on this topic, because it's been brought up before. I know I won't store my snowmobile for the summer without using Sta-Bil, though...
-Mark
Klyde
10-28-2003 10:01:13
 Re: Re: STORING TRACTOR FOR WINTER. in reply to SmartAxe, 10-28-2003 09:04:12
BIG DIFFERENCE between storing winter grade fuel over the summer and summer grade over the winter!!! Flash point is different. I know 1 thing I clean a lot more carbs in the fall and winter than I ever do in the spring. Use stablizer if you want but I just think it screws up good gas.
